Radeon Omega drivers
Jim_
Post by Jim_ »
I'm just about to install the omega radeon mobility drivers onto a dell laptop which has a radeon 9600.
Has anyone had any problems installing these before.
Cheers
Jim
yes we can highly recommend using those drivers! They open loads of usefull settings.
Edwin and i both run them on our laptops (radeon 9200 and 9600)
Jim_
Post by Jim_ »
LarsAttacks_
Post by LarsAttacks_ »
hello everyone!
could you explain the advantages of the OMEGA drivers (copared to the CATALYST) please?
when trying to install them, it prompts that i dont have directxp installed, which i have. is this serious?
thx in advance,
LarsAttacks
i,ve had this msg before on my old Sony laptop but it was problematic.
with the omega drivers you often get more options to configure your displays. (like overscan for the tv-out) But if you are not missing any options don,t bother .. if it aint broke don,t fix it!
lotech_
Post by lotech_ »
It also is modified to add support to Mobility cards which are missing from the default Catalyst Drivers. ATI leave it to individual laptop manufacturers to update the drives (which often never happens). Omega drivers or even the official ATI.com drivers with a modifed inf for support will no doubt improve your drivers for you card.
Ruud_
Post by Ruud_ »
soo were can I find these Ati Radeon OMEGA drivers. Right now I am using the cataclyst or hydravision from ati.com
Ruud_
Post by Ruud_ »
ahh i see i was tooo lazy just search engine 'radeon omgea drivers?' duhhh thanx! i guess 2.5.67 is the latest version of them
edwin
Post by edwin »
sometimes it enabled the theatre mode on ati cards. theatre mode works just like dvddmax.
videoteque_
Post by videoteque_ »
Omega Drivers for a GeForceFX 5200Go????
Lotech can you say which .inf file can we modify???
