Record @ fix frame rate
Bang Boom Ben
Post by Bang Boom Ben »
Are there any solutions or workarounds yet for recording with a fix frame rate? For example exactly the same rate of the footage clip?
b
macd
Re: Record @ fix frame rate
Post by macd »
Same problem.
Have a set built, trying to export some of it for the DJ's to play for times I'm not there. Clips all at 25fps, recorded clips have random frames rates which fall out of sync with the song when reimported to resolume (these are triggered by Ableton with the same song).
Tried export the clips via Quicktime with a set frame rate (25fps) which helps a bit but still not right.
Any solutions out there? Setting the frame rate for the record option in preferences would be ideal..
MacD
