Change Record Codec
- Bang Boom Ben
Re: Change Record Codec
Hey Ben
The short answer is you can't. Long answer is that at the moment Photo-Jpeg is the only codec that can encode fast enough to get decent write speeds. We're looking into adding a stable fps setting in future, and then we can also re-assess the state of codecs at that time, but at the moment that's how it stands.
- Bang Boom Ben
Thanks for the answer. How much would it take to convert a recorded video afterwards in he background of the program to DXV? Would it drop the performance significantly? Because I really adore the record feature. Sometimes I´m building entire sessions on it staring with one clip and remix it endlessly live. Problem is though, that recorded clips without converting into DXV need much more performance.
b
b
