That's the problem ; I can't try 'cause I think to buy it via internet on the Dell's web site. And I would be sure that it can run Resolume with this graphic card. Is this card had dual monitor ? Enough memory ?
well you should check the specs of the computer to see what your actualy buying, why buy a GeForce FX Go5200 if you dont know if it has a feature you are looking for?
be sure to check if the videocards memory is shared.
its common in laptops to share the RAM with the videocard so they can say its a 64 MB card when its really a 32 or less...
