audio video recording
l.o.r.e.
Post by l.o.r.e. »
hello everybody. When i used the recording function on resolume I get to different files for audio and video. I understand that this is normal but why cannot resolume make a single file? I have searched in other forum but I am not sure about the correct answer.
My question is: what is the best and updated way to put everything together again? A video-editing program? Which do u suggest? Are there any tricks to make a new file that is perfectly synchronized?
HerrNieDa
Re: audio video recording
Post by HerrNieDa »
the problem i think is that resolume recordes not 25fps all the time if your machine is too slow, so there seem to be problems at syncing...
the best way to capture your output is with dvd/blue ray recorders or similar products that record video...
i think we'll have to wait for a new version where this gets fixed... also you should have a good computer with fast enough harddrives!
l.o.r.e.
Post by l.o.r.e. »
how can I see if my recorded video dropped some frames?? I have a mac pro i7, 2.66 GHz, 8gb ram..
