Rerouting layers
DayVeeJay
Rerouting layers
Post by DayVeeJay »
Is there anyway to route the output of a layer as a clip on another layer? I did some crazy keystoning this weekend on two projectors. Each one was connected to its own DVI output from the computer. DVI out 1 was the left side of the screen and DVI out 2 was the right side of the screen within resolume.
I had my V4 connected to a firewire capture card. That DV input was imported on a layer clip on two different layers. One layer took care of the left projection screen, and the other the right.
This method worked great for the DV input but not for when I wanted to play some clips that where on my hard drive. Is there a way to route a layer output to a clip?
Also, is there a way to take a screenshot of the screen output to aid in the creation of masks?
VJair
Re: Rerouting layers
Post by VJair »
DayVeeJay wrote: Also, is there a way to take a screenshot of the screen output to aid in the creation of masks?
output menu -> snapshot.
DayVeeJay
Post by DayVeeJay »
Thanks Air!
eneko
Post by eneko »
hello people!
I´m a resolume 3 begginer, and I´ve been trying to route diferent layers to diferent video outputs, but the only options that I´ve found in the outputs advanced menu are top, botton, left and right, half screens.
For the moment I am workinf with one screen and to projectors, and what I need it´s to display different layers of my comp in each proyector. I´ve read that it is easy to make it, but I can´t find the way.
Hope you can help me!
DayVeeJay
Post by DayVeeJay »
Say you have four outputs and four layers. Under advanced output setup, make each output 1/4 of resolumes output. So resolumes output is divided up into four different squares. Now on each of those four layers, scale them down to 50% and align each one to a corner of the screen.
