Wanted FFGL Crop Plugin
sleepytom
Post by sleepytom »
I really need a plugin to crop the edges from clips in resolume. i'd like it to have 8 parameters top, bottom, left, right edge position + softness per edge.
I will pay someone $100 for this plugin if it works on both mac and PC.
I could probably do it myself in Openframeworks, but i simply don't have the time at the moment.
please contact me via phone or email if you can make such a plugin.
cheers
tom
tomATsleepytomDOTcoDOTuk
HerrNieDa
Re: Wanted FFGL Crop Plugin
Post by HerrNieDa »
have you tried the keystone mask effect...
the softedge you can get with a mask, an extra layer or with the vignette effect if this is enough...
