Avi file not loading on resolume
veejayknightvison
Post by veejayknightvison »
hi
am working on resolume 2.41 from last 02 years on my laptop never faced any problem. i just built a new desktop pc for myself with intel core 2 duo, 6gb ram, 1.5tb hdd, nvidia cuda graphic card with window xp.....i transfer all my avi file with mjpeg codec some of my file its not loading on deck the movement i select to load the file resolume 2.41 become still i have install direct x 9 & flash player.....i have uninstall & reinstall resolume 2.41 but the problem is same.......can anyone suggest me what shall i do now......it will be a great help for me....
regards
veejay knightvision
HerrNieDa
Re: Avi file not loading on resolume
Post by HerrNieDa »
is the mjpeg codec installed?
what nvidia drivers do you use?
maybe try an older/newer one or alternative omega drivers
