(Someone asked this already in
another thread but i don't think there was a reply)
Can i view the v2.0 16.9 display 'letterboxed' in my standard monitor or do i have to lose a bit off the side?
						v2.0 widescreen question
yes you will be able to see everything,
the interface is adjusted by the resolution of your screen. By the way the interface is designed for use with 1024x768 or 1280x1024
so it's not really wide screen. If you have the higher resolution some things in the interface get more space, that's all there is to it. It' just that we thought that if you have a bigger resolution you should be able to benefit from that.
cheers
cheers
