Help!
I'm new to resolume but not VJing.
I just downloaded the trial of Resolume 3 and the effects are missing from the effects panel (video and audio).
They are within the application folder Resolume Avenue 3.3.1>plugins>vfx>etc but don't appear in the application itself.
I'm using a Mac w/Leopard.
Any help would be much appreciated!
Missing Effects
Re: Missing Effects
Did you check the settings? To do so go to "Preferences" select the "Video" Tab, and be sure the FX folder is listed there. - Hope that helps.
Re: Missing Effects
i've got the same problem, but i couldn't find out preferences, where's?
