Can't use 'levels' and 'Zoom' effect simultaneously on a channel?
Kloo_
Post by Kloo_ »
When i use the 'LEVELS' effect on my live feed (by assigned key) and then try to use 'ZOOM' i lose the 'LEVELS' effect.
Because of low/light condition of clubs i Always use 'LEVELS' however also want to add other effects.
Will 2.0 allow for this ?
levon_
Post by levon_ »
what you can do is put the levels filter as a global effect, that way each clip can have its own effect.
to make the levels a global effect drag it to teh space next to the preview window.
another way you can do it is to use petes freechain tool to like the zoom and levels free frame plugins together.
resolume 2 allows for 3 global channel effects afaik, though it might have changed.
Kloo_
Post by Kloo_ »
awesome.
Thankyou levon.
Like every1 i can't wait for next version !
r2 can have 1 effect per clip and 3 gobal effects, so yeas you can do levels and zoom at the same time.
