For some reason my quartz clips freeze and don't respond in avenue in the middle of my shows. This problem is kinda on/off and I can't seem to recognize why it is happening. Once I delete the clip and load it again it works. Any ideas?
Thanks ahead,
Shoken
Resolume and Quartz
Re: Resolume and Quartz
Hey Shoken
It kind of sounds like a memory leak issue, but it's hard to say without knowing more about the patch and your setup. Can you share the patch?
Hi
The patch is pretty basic, It's a cube with input splitters on x,y,z position + x,y,z rotation + width,height and depth. All in all nine parameters. What do you mean by memory leak?
Shoken
Shoken
It could have been you were doing some crazy stuff in the patch which would cause the computer to run out of memory (buffering images in a queue patch for instance). Since your patch is apparently so simple, I'm a bit baffled by it really. Is there anything you can think of in your setup which causes it (applied effects, external controllers, anything)? Are the mins and maxs of the splitters set correctly?
Hi Joris,
The mins and maxs are set correctly. I'm using the korg nano and the akai Lpd8 as controllers. I'll try to run a few tests with the effects to see if one of them triggers the freeze...
Thanks,
Shoken
Thanks,
Shoken
