After upgrade the flash player to 10.2 version in a XP machine, Resolume 2.41 not play swf files correctly.
Some swf files with movie clips inside play at low fps (only movie clips or sprites).
I try to uninstall this flash player version and reinstall an older, but with erlier versions (below 10.1) swf files not play anymore.
Updated flash player not play swf correctly
Re: Updated flash player not play swf correctly
Hi. I have the same problem. Flash files stopped playing after the latest flash update last night. There seems to be no turning back from this point.
Any suggestions, please?!
you have to unistall flash player 10 for internet explorer (so you will never play to farmville in facebook with internet explorer
http://kb2.adobe.com/cps/141/tn_14157.html
restart windows
than install an older versione of flash, like the 9
http://kb2.adobe.com/cps/142/tn_14266.html
and then resolume play flash movie right.
nb: you can still have flash player 10 on other browsers like chrome or mozilla and resolume work good.
restart windows
