matrox 750
arnold_
Post by arnold_ »
hi there. First of all Photonic festival was wicked! Resolume thanks for showing up. hope your party was oke too bad i could not be there!
Other things now. I bought a matrox 750 and in resolume i have the problem that all output is in strobe..anybody know what to do? Settings in resolu,me and matroxpowerdesk seems to be oke
Regrads,
Arnold
SuperficiaL_
Post by SuperficiaL_ »
Hi Arnold,
had the same problem with my parhelia.
my problem was the refreshrate.
so set the second monitor to 50Hz if is on 60Hz and 60Hz if it is on 50 Hz.
good luck,
SuperficiaL...
arnold_
Post by arnold_ »
Thanks going to give it a try
Kevenius
Post by Kevenius »
And if that doesn't work?
Did it work with you Arnold?
