videomapping a graphic EQ. effect
fordaloveable
Post by fordaloveable »
Hi guys,
Im veteran animator but a newbee on resolume & realtime effects, so pls forgive me when i post silly questions for now .
I want to map a graphic equalizer effect by projecting audio responsive colored bars onto some real objects that are positioned on a stage. I guess i should use the audio analysis function in resolume to drive parameters for the specific graphic elements that i want to respond to the audio? For instance.. I would like to isolate low(base) audio frequencies (the audio input comes from the dj) and make a certain block/bar/graphic bounce like a graphic EQ. Basicly i hope that i can make the audio control the position or scaling of a clip.. or perhaps control the position of a mask which will reveil or hide a portion of the underlying graphic based on the audio input.
Any tips or insights are very appriciated.
Thx Mark
DayVeeJay
Re: videomapping a graphic EQ. effect
Post by DayVeeJay »
While I'm sure you could do this with Flash with excellent results, you could also do this almost entirely inside resolume. The results may not be quite as nice but I have yet to try it so I cant say for sure.
Create a solid square with a transparent in photoshop and save it.
Assign the image to a layer.
Make the height of the object react to the sound
Adjust sensitivity and frequency response as desired.
Repeat for each eq band
Yes, it's a messy configuration but it would work
