BPM Counter stopped counting.
Hey ho,
the Bars.Beats Counter stopped counting. I find no reason why?
Someone has an idea? :)
Greets
HerrNieDa
Re: BPM Counter stopped counting.
Post by HerrNieDa »
go to preferences/audio and select a soundcard. normaly this is the fault!
hmm.. that was my first tought too. I even tried to use a external soundcard. nothing happend - the counter didn't moved.
After I re-installed resolume everything was fine again.
So I started again using the midiclock of a Kaoss Pad 3....fine. Then, after two days I needed the KP3 in my Audiostudio. So I disconnected it from resolume.
After I started resolume again without the KP3.....BLÄÄM....the beatcounter stopped counting again.
Hmmmmm.....but why :?:
Greets
