Screen mapping/warping
redrhino
Post by redrhino »
I have just downloaded the demo to have a look because I am investigating systems /programs to help me do projector mapping.
I look the of reso so far but can you tell me if there is a warp facility so I can map to 3d real objects via a grid rather than just masking 2d layers. ie. a mesh warp on grid points in x,y,z .
I have experience with Pandora's Box and Hippotizer where I can shape the the output to the projector by screen warping but need to have a non hardware specific solution that I can apply warp meshes to layers/outputs?
Any advice would be welcome.
Thanks and regards,
Ian
redrhino
Re: Screen mapping/warping
Post by redrhino »
Ok, I just stumbled on IRMapio but is there something similar that I can shape/warp in 3 dimensions?
Oh my head hurts!!!!
GeeEs
Post by GeeEs »
IRmapio is what you want/need...
Otherwise you can use the keystone plugin (inside Avneue) on layer/clip level... This will only work on square/rectangular shapes.. so curved shapes are a bit more complex ;-)
Textmachine 3D is also a great tool for mapping (It's another software package apart from Avenue)
redrhino
Post by redrhino »
Thanks, I'll take a look.
redrhino
Post by redrhino »
I assume I have to paste the irmapio plugins in to the resolume plug in folder first?
