Help !! looking for source code of a simple example
vjDev
Post by vjDev »
Hi
I´m a little lost :-(
I wrote a simple example but I can not get it to work
I'm trying to read a text form
Code: Select all
private var eventId:StringParameter = resolume.addStringParameter("Text", "Resolume");
I Checkout the Flash examples in the media folder of Resolume. but Its missing source code of the swf
Also read all the details about creating Flash movies for Resolume please refer to the Flash chapter of the manual
I guess I'm missing something !?
thanks
ResolumeTest.zip
simple test
(20.32 KiB) Downloaded 893 times
Re: Help !! looking for source code of a simple example
Don't know about your simple example (unpacks as libs and src folders for me, no working .swf in there), but here's the TextZoomer .fla and .as files (that should actually be included with Avenue).
TextZoomer.zip
(8.51 KiB) Downloaded 952 times
vjDev
Post by vjDev »
Here is what I'm missing , I'm develop with Flex Builder 4 and I do not have fla files there
what software are you using to develop wsf ?
How can I see the source of the fla ?
thanks
Flash...http://www.adobe.com/nl/products/flash. ... moid=BPBWO
dbassix
Post by dbassix »
Does anyone know how to implement the resolume as resources to flex or flashdevelop?
