Audio FFT gain issue
olivepixel
Post by olivepixel »
I often use the gain to turn an effect off or on (because it can then be assigned to one knob on the controller) but it seems that it doesn’t go right down to zero which can be annoying at times...
Re: Audio FFT gain issue
Hey Olivepixel
Is the audio input gain in the Preferences set to 0 dB as well? In that case I can make all the noise I want, the parameters don't move one bit when the individual gain is set to 0.
If you're experiencing differently, could you provide some steps on how to recreate the issue?
olivepixel
No, it’s not set at 0 – because the gain in the preferences isn’t accessible (in that it’s tucked away and not mapable) it’s not practice to modify this during a show. It would still be nice if the individual gain could somehow override this at the very bottom, and ‘turn off’.
Making the master gain midi-mappable, or available in the interface has been mentioned before, and has been added to the list of requested features.
