ausio analyser
thomas_
Post by thomas_ »
i wish i could control the audio analyser. it just jitters when i gain-up. no line-in. no wave-in.
could be a more vague than this? please refer to the manual to see how the audio analyzer works
mortischa_
Post by mortischa_ »
yes great program but i have read the manuell and how can i get sound input wich source,ik snap er effe niks van
Trunx_
Post by Trunx_ »
ok dude, here's the deal. If you want to change the input that resolume uses for the audio trigger, simply do to the audio mixer for your sound card and select the input in recording to whichever input you like. sorted.
bl0mmie_
Post by bl0mmie_ »
what about multiple sound cards ?
it seems resolume has a favor for my "soundcard" in my usb cam over my internal sound card. is there a way to choose a device ?
thanx in advance
cat_
Post by cat_ »
In your control panel multimedia/sound settings, there should be a drop down list of sound cards and stereo input pairs that you can select, make your choice in there and all windows apps will default to that input.
