midi triggering sync problem
nfcarbone
Post by nfcarbone »
Searched the forums but no problems exactly like this one.
Computer 1: Lenovo 2.4ghz core 2 duo, windows 7 64-bit, cubase 5, m-audio profire610
this computer sends midi clock and midi key information out to
Computer 2: Toshiba Qosmio 2ghz i7 quad, win7 64-bit, same audio io, ableton and resolume (GeForce GTX 460M, dxv codec files)
I have a korg padkontrol triggering sound samples in cubase on Computer 1, cubase midi channel is sending midi out to Computer 2 where resolume takes it and triggers clips.
It was working fine!! perfectly in sync, but now I realize that sometimes it is delayed about 100ms ONLY while cubase is playing. If cubase is stopped and I hit the pads, the sync is PERFECT. Once cubase is playing it is hit or miss whether or not I will experience this latency. Sometimes it is perfect, 2 minutes later out of sync. Driving me crazy!! This problem will completely ruin the impact of the performance if I can't solve it. Any help or ideas?
thanks.
