Hello guys,
i have a problem. i want to mapping a video o a round object. I found the keystone effect, but there i can only map the videos on plane objects. Have anyone an idea to solve the Problem?
Mapping on a round object
Re: Mapping on a round object
What exactly do you mean by "mapping"?
If all you want is a crop, you can apply a global mask under Composition Properties.
if you have a mac you can try quartz composer (there is a 16 point keystone at 1024 site, just google for it
on pc, a vvvv patch should do the job.
also IR Mapio should work fine with round objects i think, maybe the best solution for resolume!
