Reading a few other posts I gather I know the answer, but I wanted to check. I want to output 2-3 projectors as one big image. Does Resolume auto-create the additional image on the edges to overlap/overlay the projected images to then edge blend on the projectors? Don't need to edge blend in the software, just want the softare to automatically allow for the overlay for me to blend.
Gathering Resolme doesn't do this without a lot of fiddling... true?
						Multi Projector Screen - Overlap
Re: Multi Projector Screen - Overlap
If you're using individual outputs on your GPU for this, you can set an overlap via the advanced output options. If you're using a Matrox Triplehead2Go solution, unfortunately this is not possible in Res3 (but is coming in Res4, as well as integrated edge blending).
