Audio-Reactive Flash
bim-bong
Post by bim-bong »
Hello guys, I am new in this so I would really appreciate if someone could help me! Basically we installed LED screens or system for an event we are about to have with music. What I am having trouble finding is motions that move with the music. I've searched everywhere on the net in order to buy some or download cause I really need it but I couldn't find anything. Can anyone suggest a website where i can download all the motions or visual effects that move with audio?
Please help me cause the show is on Saturday and i really neeed some!!!
Thank you.
GeeEs
Re: Audio-Reactive Flash
Post by GeeEs »
All parameters/effects/clips can move/react to audio.
Set a valid audio input in preferences and start mapping parameters to Composition Beats or external input!
It it's not my business at all, but I would work the other way around next time ;)
First make sure you know what to do with the software and have material to play, and then start building shows! (especially when you spend money on LED screens... )
Good luck saturday!
bim-bong
Post by bim-bong »
Doesn't the website offer any downloads? the equalizer they have in the footage section, it goes with the music right?
GeeEs
Post by GeeEs »
Resolume website has a great shop with lots of footage. You could use all of them using the audiomapping functions within Resolume Avenue. It's a bit fiddling around with the FFT parameters, but you should be able to make them reactive to any audiosource within Avenue. Also have a look at the Wormhole VST plugin (Not Resolume related but usable within Resolume) check this topic: http://www.resolume.com/forum/viewtopic ... ole#p20727
rxfromparis
Post by rxfromparis »
you want visuals that respond to music ?? Hire a VJ :|
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
