APC40 controller
Today i tried to use my iPad as and additional monitor using the app "AIR DISPLAY" with AD active and running properly Resolume will nor open and generates a crash report every time i attempt to open resolume3. even with res running if i attempt to add the iPad through the launch app resolume crashes. I know the immediate answer
 " dont use the ipad with AirDisplay so i wont but dose any one know a fix for this or other option to use the iPad as an aditional monitor to view my output going to the projectors on. as it is I am sending mini DVI to a VGA 4x hub and feeding two projectors and plasma dysplays.
  " dont use the ipad with AirDisplay so i wont but dose any one know a fix for this or other option to use the iPad as an aditional monitor to view my output going to the projectors on. as it is I am sending mini DVI to a VGA 4x hub and feeding two projectors and plasma dysplays. Mahalo
Yay Fuzzy
