Its just happened that my second project file has stopped outputing.. I can click on the preview tabs below the clip and i see the preview but nothing will work to click on the clip to activate it. Luckly enough i save up versions frequently.. so this time i just went back one version and it was working. This happened once before as well and i wasn't so lucky. I had to go back several versions (equaling a whole days work) to find a version that would activate the output..
Anyone know what causes this? how to avoid it or how to fix it..?
running an ati 5870 gxf card.. 4gb ram... quad core 6600 .. dell inspirion 530 with two ssd drives..
project(s) stops outputing on startup!
Re: project(s) stops outputing on startup!
Hey Greg
Do you see a yellow bar appear on the clip after clicking it?
