3 X HDMI live video input in 1 PC
n1ente
Post by n1ente »
Hi all,
as the title says i need to make a show acquiring 3 hdmi sources and have it in 3 separate layers in resolume to play with.
I need an external solution, searching here in the forum i found that the developer saying they are working with Blackmagic SDK, so this sounds good to me and i cannot find any other recommended solution
so the question :
1 Can i use 3 Intensity Shuttle in 1 pc (3 X USB 3.0 connections) all running smooth at 25fps acquiring through HDMI ?
2 What's others better options could be ?
Thanks in advance
fruitygreen
Re: 3 X HDMI live video input in 1 PC
Post by fruitygreen »
Intensity Pro cards is an option. Got 6 installed.
Intensity Shuttle , may be limited to USB 3 hub. Although you may have multiple USB 3 ports, they may be sharing the same bus which has a max.
My board has 2 separate USB 3 controllers and I can only install 1 Intensity Shuttle per controller.
Stickygreen
Post by Stickygreen »
I've tried 2 BM Intensity pro cards and FPS stays nice and high.
