hello,
in resolume 2 every video clip automatic go in extend mode when played, in avenue the video are at real resolution and there is a button to extend each video to fullscreen.
i think is better now, becouse we can use togheter video with different aspect ratio, and without lose proportion we can zoom or extend as we like.
but sometimes it is trouble that i click on an old loop (the old loops are low resolution, but sometimes are so nice. that we have to use them) and it go out as a little square in the screen becouse i forgot to extend or zoom it.
i think would be a very nice stuff if we can have a button to enable or disable automatic extend of video.
thanks.
auto extend video
Re: auto extend video
you can activate this at the layer properties for every layer...
you are also able to use layers for 16_9 footage and other layers for 4_3 this way without loosing proportions
a nice feature also would be to fix only width or height and lock the aspect ratio (which is not the case so far i can see)
- rxfromparis
+1
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
Feature request made for the 'resize while maintaining aspect ratio'...
