Twitter feed
RoozJ
Twitter feed
Post by RoozJ »
Does anyone have experience in importing Twitterfeeds into Resolume? Should be possible with Flash. I'm not a developer so I'm looking for a simple solution.
GeeEs
Re: Twitter feed
Post by GeeEs »
I think twitter has some sort of RSS feed for your timeline isn't it? If so...
I'm not at home right now, but I remember that in one the user/media folders of Avenue there was a "rss import" flash example.. This should work right out of the box.
Re: Twitter feed
Hmm.... I think it could also be possible with a vitual webcam software.
Some of those tools let u define desktop regions...in such a region you can place a twitter realtimefeed window... all u have to do now is to insert the virtual webcam into resolume...
Greets
RoozJ
Re: Twitter feed
Post by RoozJ »
Hey guys,
thanks for your advice. The rss.swf is certainly worth a try.
I've tried to follow a usersfeed and that did work. A searchfeed however didn't work. It seems Twitter stopped supporting RSS and uses a new technology OAuth. Some developerfriends are trying to help me with it now, I'll keep you posted about the outcome.
I'll try the virtual webcam option tomorrow, it's a creative idea, worth trying. Thanks!
pfelberg
Re: Twitter feed
Post by pfelberg »
I know a third party solution that will allow you to video capture Tweets, SMS, MMS, photos from cell phones and Facebook Wall posts as well.
The bad news is that it is a stand alone package that will cost you US$350,00 and only runs on a PC.
I usually grab the video output signal from the PC to the Mac but results so far are not very good - composite video ; (
Yes, this week I found (here at Resolume forum) an alternative to send VGA signal from the PC to the Mac but that´s another 300+ dollars.
juicewon
Re: Twitter feed
Post by juicewon »
5950x 3090 FE 128gb DDR4 2tb NVME X3
M1 Max MacBook Pro 64gb 2tb NVME
RazerBlade 16 4080 32gb DDR5 4tb NVME
Re: Twitter feed
So now...this topic should be finaly solved :D
synapse_gh
Re: Twitter feed
Post by synapse_gh »
MkUltra
Re: Twitter feed
Post by MkUltra »
Looks like Twitter has changed their API again as of June 15th-- everything wants OAUTH two step authorization now. I was using the Qtz rss reader, but I have no idea how to modify it to do two step/pinless auth with that. So-- went back to Flash. Works as well as it did before-- does @user as well as #hashtag searches.
http://emaqdesign.com/video_loops_flash.html
