no value on effect parameters
Dodo_
Post by Dodo_ »
in resolume 2.0 there's no value on the 4 effect parameters. there was in 1.51.
i can't play all my files coded with picvideo mjpeg
i can't play my swf files if they aren't in the same partition or hd.
the sliders if the effect parameters should get the same sliders as the playhead so you can adjust the in and out-points and it will then show the parameter value on the playhead.
