Searching - customizable software midicontroller
Hey,
for my vj gigs I'm using a touchscreen...to operate Resolume. There it only one single problem:
Resolume isn't very touchfriendly. My idea is now to find and use external software to remote resolume.
This external software should be able to create a grid of software midi buttons on my screen...wich are fully customizable. I would like to define a background picture for every certain button.... the midi and/or osc message....
Result:
A fullscreen clip laucher. :twisted:
Any ideas? Other Solutions?
greets
rxfromparis
Re: Searching - customizable software midicontroller
Post by rxfromparis »
i'm thinking you could use Ableton Live and Max for Live to make that kind of tool ?
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
Hi rxfromparis,
in wich way I can combine MAX FOR LIVE and LIVE to create such a tool?
Best regards
rxfromparis
Even better, take a lok at this :
http://www.sensomusic.com/usine/
touchscreen, osc, midi, programmable, looks nice
and for Max for Live, i'm just starting, so cat be much help (yet ) ;)
levon
Post by levon »
you dont need Max 4 Live, you just need MAX.
ive used a 10" Touch Screen and made an interface in MAX, using sliders and buttons. i was just using midi to communicate from MAX to Resolume, but you could also use OSC.
it took quite some time to make the interface, and i dont use it any more.
sounds good.... is it also possible to define a button background?
Greets
LG
VJair
Post by VJair »
seems a bit over complicated to me... why not just use a keyboard / novation launchpad / monome ?
@ VJair
thx...for your answer...but..not enough buttons, no visual feedback and no thumbnails are shown on a keyboard, launchpad or monome.
The composition I'm using has up to 500 clips in one deck...I think it's getting quite difficult to have access to every certain clip with the hardware u have recommended me.
Best regards
