FrRGBDelay-beta1
Godzil
FrRGBDelay-beta1
Post by Godzil »
Hello there
Someone is using this FrRGBDelay-beta1 plug-in in R3?
http://www.1210visuals.net/index.php?op ... &Itemid=66
I want to know if u have a R3 crashes. When is running.
Tschoepler
Re: FrRGBDelay-beta1
Post by Tschoepler »
no crash. but some clips started to act weird lately: I applied the effect to a solid layer with some other effects. Then coppied that clip and made some adjustments and copied it again. Now the third clip just won't show any output! not at all! So what I want to say: it is buggy but doesn't crash my Avenue. I'll do some more research on that when I am back home.
Rene
Post by Rene »
Hi Godzil,
beta1 of the RGBDelay pluging is very ressource intensive, I'm aware of this issue and I will address it in beta2. For now, you should not use more than one instance at the same time - really, don't create more than one instance of the plugin :!:
Anyhow it should not crash Avenue in any case. Please contact me directly to sort things out. Either via the Resolume forum or use the E-Mail contact address provided at 1210visuals.net
cheers,
Rene
Godzil
Post by Godzil »
Good work, Rene. Keep it up.
Tschoepler
thanks for the feedback
