unexpected file format
ninjaturtle_
Post by ninjaturtle_ »
bansai everyone!
just read thru the manual to check out the flash variables. as i wanted to open the bars.fla file in flash mx i get an UNEXPECTED FILE FORMAT ERROR (or something like that... my version is german).
whats wrong wih it?
anyone knows?
could the programmers maybe give some more detailed information on scripting in flash...?!? the manual is kond of .... useless....
regards,
ninjaturtle
SuperficiaL_
Post by SuperficiaL_ »
hi ninjaturtle,
i had the same problem.
i think its made with a newer version of Flash...
ive got Flash MX and probably its made in Flash MX 2004...
because the other (older) Flash files are openable...
Greetz,
SuperficiaL...
ninjaturtle_
hm... okay... thx.... what a bummer!
i have another question regarding flash:
is itr possible to make a dynamic text flash file with more then one line?
how?
thx.
SuperficiaL_
Hi ninja,
just turn on multiline in the properties panel of the dynamic text frame in flash.
Greetz,
SuperficiaL...
site_
Post by site_ »
This might be bit off your question, but you could put multipler varibles into flash with a bit of scripting on the flash end.
When typing they dynamic text field in resolume, you could use a delimeter to seperate values or text you like to put into the flash. eg using the '^' as a delimeter, youre text in resolume would be a^b^c^d .
In the flash newVarible=varibleFromResolume.split('^')
So now flash will split the varible from resolume into a array and you will get,
newVarible[0] = a
newVarible[1] = b
newVarible[2] = c
newVarible[3] = d
So now you can use these to control 4 diff stuff in flash.
Hope this is helpful.
Cheers.
site_
Post by site_ »
Made an example swf.
File at http://www.iworkforfun.net/midibox/textflash.zip
Works like it should. Just that in resolume it doesn't always update real time. Sometimes you've got to load it to the channel again after changing the text in resolume. Sometimes you don't.
Cheers
ninjaturtle_
thx for posting this, but unfortuneatly this file does not work either. still gettin that error....
btw: i have flash mx version 6.0.
can't believe, that flash is not compartible with older/newer fla-files
site_
Post by site_ »
sorry... am using flash mx 2004... that's why you get the error... will put up a version 6 one as soon as possible..
site_
Post by site_ »
here's a flash mx version..
http://www.iworkforfun.net/midibox/flash.zip
cheers
Papui_
Post by Papui_ »
hi!
please programmers tell us which version those FLAs are supposed to work with . I have funny ideas for scripting but I´m quite stucked whith this versions problem!!!
thankyou anyway....
