Increasing quartz objects resolution in Resolume ?.
Yulhe
Post by Yulhe »
Hello !
I want to use some quartz particles generators with fixed images instead of a gaussian, but I notice a very bad resolution when I use the object in Resolume (hight pixellization), whereas the resolution is perfect when I test the patch directly in Quartz (even in full screen mode).
Is there a way to control (and to improve) the resolution of quartz flux in Resolume ?
Thank you for your help,
Regards,
Yulhe
Re: Increasing quartz objects resolution in Resolume ?.
Hey Yulhe
You can click on the little cogwheel icon in the clip properties. This will allow you to specify at which resolution the patch should render. By default this is the resolution of the Resolume composition when you first loaded the patch.
Make sure that both your output resolution, composition resolution AND patch resolution match when you want to have pixel perfect rendering (like the QC editor).
