Greetings to everyone.
I just got a brand new mbp
2.53 GHz Intel Core i5
4 GB 1067 MHz DDR3
NVIDIA GeForce GT 330M 512 MB
My new machine came with Mac OS X Lion 10.7.1
Im trying to work with resolume demo to test if it suits my needs. today i was testing different media and when i try to load quartz compositions, program stops responding. It does not freeze completely.... i can move around selecting different clips but these do not show in the preview/output window after trying to load the comp. plus hangs when quiting.
symptoms are the same as shown in
viewtopic.php?f=14&t=6682&hilit=quartz+crash
hopefully i won't have to format my drive, i have had this computer for less than 2 weeks and spent 3 days installing everything.
I tried 3.3.1 3.3.2 and 3.2.0. demo installers and all with the same issue.
A have all my OS updates.
The problem was caused by Kineme Original Plugin with i installed like all other patches within
/HD/library/graphics/quartz composer patches
instead of
/hd/library/graphics/patches
(as its instructions noted)
everything seems to m be running smoothly with qc compositions so far.
Quartz Crashing Avenue (SOLVED /// UPDATE)
