maximum columns?
newfuturenow
maximum columns?
Post by newfuturenow »
I cant find any info on what the max amount of columns resolume can handle is.
I have an Ableton live set that I am synching up with that is over 250 columns long.
Will Resolume be able to handle it ?
Re: maximum columns?
Hi bravenewfuturenow,
...I don't even know if there is a max. amount of columns....I never reached "the end"....
Shure..there is a hardwareresource-end :roll: .. but u will not reach it with one maybe two layers and
250 columns.
....I allready build a deck with more than 400 columns...so..I think it should work. ;)
Greetz
newfuturenow
Hey infiniteCosmowe
400 columns?! wow wow wow
Thats good to know, thanks!
edwin
Post by edwin »
There is no limit software wise, but watch your memory usage!.
We advise you not to use more than let's say 50 columns per deck. It's better to split files over multiple decks.
yochee
Post by yochee »
i also work with quite endless decks, cause im too lazy to switch (even if it would be better) :mrgreen:
....in my case its not my lazyness....switching destroys my ONFIREMODE :twisted:
VJair
Post by VJair »
i also use a deck with hundreds of columns, never experienced a problem with it myself.
Tschoepler
Post by Tschoepler »
cosmowe wrote:....in my case its not my lazyness....switching destroys my ONFIREMODE :twisted:
harr harr 8-)
gregsully
Post by gregsully »
The problem is in total number of clips used vs memory. If in Layers or columns.. Doesn't seem to matter to me..
newfuturenow
I have made a set with 300+ columns to sync with live - all works great, the set saves but each time I quit the software spins out the system and I have to force quit, any one any ideas why and how I can stop this from happening ?
any thing I can send to your guys in resolume to see if it you can work out why its happening ?
