Record best possible output simply
magik
Post by magik »
Hello I am new to Resolume and Video -- I come from a Flash background.
I would like to know how to best record a live set to be brought back into a video editing program at the best quality or very good. I am making a music video with Flash and video using Resolume.
The record function produces much too low-res quality video.
I am on a tight budget, so I am looking for a simple cheap way to record the set nicely and bring it back in to after fx etc program.
Thank you for your help. I have looked for a simple answer to this question but had not found one yet.
rxfromparis
Re: Record best possible output simply
Post by rxfromparis »
i get my best results by using Fraps :
http://www.fraps.com/
it's a videogame recording software, i've capture at hd resolutions :)
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000 :))
Rene
Post by Rene »
If you're on Mac, you could try Syphon Recorder.
Resolume --> Syphon Server FFGL Plugin (at the end of the FX chain at the composition) --> Syphon Recorder --> Harddrive
http://syphon.v002.info/
magik
Post by magik »
thank you!
