Hi!
I bought an adapter Midisport 1x1, but I can not receive MIDI clock.
which adapter you advise me to buy so that they can receive the clock from ableton?
thanks!!!
midi adapter for midi clock
- rxfromparis
Re: midi adapter for midi clock
gonna need more info to help : mac or pc ?? is Ableton on the same computer or are you using 2 computers ????
desktop: Windows 7 64bit , i7 920 2.66Ghz, 12Gb Ram, GTX 950 2Go, WD Velociraptor 300Go, terratec asio phase 26 usb soundcard & midi,Novation Nocturn controlpad, Akai MPK mini, and soon to come : BCR 2000
sorry
I use Macbook pro and Ableton is on other PC
thanks!
thanks!
- Tschoepler
Have you monitored the MIDI signal on both systems? on OS X i recommend MIDI-Monitorhttp://www.snoize.com/MIDIMonitor/ on Windows MIDI-OX http://www.midiox.com/app.htm
You could do this via OSC without the need for special hardware. A simple (W)LAN connection will do. Read this article for more info: http://createdigitalmusic.com/2010/03/h ... e-control/. I haven't tried LiveOSC myself but it reads promising.
Just found this as well: http://www.future-instruments.net/surfa ... Connection
Especially "How to use Ableton Live on another computer". You have to think of "this Live" as Resolume on another computer.
btw: I hate M-Audio
btw: I hate M-Audio
thanks a lot, I knew part of the OSC system
I tried the Ta Horng MIDI interface (unknown for me )..... and this works!
but Ta horng is a friend of mine... and I can not use it ....
you know some other MIDI interface that works without going through OSC?
I believe that M-Audio has serious problems!
thanks!
thanks!
- Tschoepler
I have a Focusrite Saffire sound card in charge which has MIDI I/O and my MIDI-controller's got I/Os, too.
That said, I can't give you an advise for a MIDI-only controller.
