[Crash]Loading Column into output
rabosavj
Post by rabosavj »
Hi
I can crash the tool as many times I want:
Steps:
Open the arena in macos
Load a old desk (from the samples of 3.3.2)
Arena can´t find the clips but user can relocate, so relocate and press fix all
On the loaded desk press on Column 1 to load all clips
then go to the fist desk (footage shop)
and do the same click pon column1 and... booooom crash the Arena....
Then after the crash and start again the composition is break!
Re: [Crash]Loading Column into output
I can't seem to recreate this. Does this only happen with these particular decks for you? Or for any deck that has used the re-locate function?
