cube blend / transition makes the screen blank
VJair
Post by VJair »
when i choose cube either as a blend mode or a transition on the same layer - the output goes black.
Re: cube blend / transition makes the screen blank
This was a problem with older versions of the plugins. Have you loaded the correct plugin folder?
VJair
Post by VJair »
ahhh yes! i had the avenue 3 folder selected in there....doh
