So i tested a lot last couple of days,
And i realy love the new blend mode and auto pilot.
But i only tested it on one deck, which went great, but today i was trying to make some new decks.
but it crashed on selecting the new deck.
I restarted resolum, and now i can select the new deck, but!!!
On the new deck i just created, it puts the same clip on almost every layer?
Also when i try to select multiple columns on the same layer in this new deck, I cant, only on the first deck.
Hope this helps.
Cheers...
Digital Movement
Crash on selecting decks
- Tschoepler
Re: Crash on selecting decks
just checked. doesn't happen on my system.
I opened the demo > created a new deck > switched to the deck > and added some of the demo clips. multiple select etc. working.
I also cannot reproduce it. U should send your logfile to the resolume guys via feedbackfield.
Do you like outlines? Easy Outliner on Juicebar
