Alpha issues
Tschoepler
Alpha issues
Post by Tschoepler »
Heya Res team,
I got two things to ask for… more to come :twisted:
1. I just checked one of the issues that affect my work the most besides all the other users' good suggestions. That is Alpha rendering. I checked with a comp utilizing a particle effect and solid layers. Comp file is attached. I mentioned the problem before on this thread: viewtopic.php?f=12&t=7210&hilit=+alpha. Please please please address this issue :? I use a lot of alpha within my shows and I could really use that extra layer that just sits there being a solid black layer for now. Just to make us smile again have a look at this stream from Red Giant (I was literally LOLing when I saw this) and FFWD to 4:05: http://www.redgiantsoftware.com/videos/ ... tv/item/2/.
2. Would it be possible to hide the Alpha button on the Clip Video Properties if the clip's got no Alpha? Could be handy here and there but if it is a lot o work: forget about it ;)
…… The extension avc is not allowed :roll:
50_Mask_Problem_v4.7z
avc file
(2.46 KiB) Downloaded 571 times
Re: Alpha issues
We did give alpha rendering an overhaul for R4, but looks like we need to check again. Thanks for the report. If I understand correctly, this is only with the 50Mask blend mode, correct?
VJair
Re: Alpha issues
Post by VJair »
of all the file types to block...hehe
Tschoepler
Re: Alpha issues
goto10 wrote:If I understand correctly, this is only with the 50Mask blend mode, correct?
Nope, I think it happens with other modi, too. I'll check and report back.
edwin
Re: Alpha issues
Post by edwin »
VJair, i added 'avc' to the allowed extention list
Tschoepler
Re: Alpha issues
edwin wrote:VJair, i added 'avc' to the allowed extention list
thumbs up ;)
