comma as seperator
Tschoepler
comma as seperator
Post by Tschoepler »
In europe the comma is the seperator for floating numbers and thus the key on the numpad. I rarely ever enter numbers from the toprow. Is it possible to easily make point and comma available in the numeric parameter input? I know there are other apps that can do it. Just not sure how much work that means.
Re: comma as seperator
sounds good.....
Do you mean you can use the point but not the comma, or neither?
Tschoepler
yes, I can use the point but not the comma.
GeeEs
Post by GeeEs »
+1...
I always use the numeric keypad too! and the point on the "Del" key is not working as a seperator...
