Codec Problem
FOC:EYE_
Post by FOC:EYE_ »
in manual it says to use cinepak or indeo...
using premeire 1.5 pro i exported using cinepak codec by radius... it seems to be the same one suggested by you guys... i followed the settings, key frame every 1, etc... it loads into resolume 2.0 just fine but it always gets stuck around 2/3 of the way to the end of the keyfram slider...
any suggestions???
safe
don\'t compress u\'r videos
Post by safe »
i think its better not 2 uz compression, most giga but less time...:)
i was just thinkin about dis : dya have 2 kompress or not and wich codec? but wen i dont komp' its cool...
i try indeo 5 with DV AVI and i say u, ok?
just a moment...
