Hey Resolumes,
Behavior of transitions in a multidisplayconfiguration
you can see that in a multidisplayconfiguration some of the layer transitions have different behaviours.
Some of them only have influence in their region of the composition...some of them are spreading their effect on the whole composition.... I don't really think that this is the intention?? hmmmm
Sorry for the bad videoquality...If it's necessary I would try to find a better hoster.
The transitions which are taking influence at the whole comp. are:
LowRes (small flash is visible)
MetaMix
Shift RGB
Wipe left
wipe right
to white
Greets
Do you like outlines? Easy Outliner on Juicebar
