Retrigger via Thumb not possible when BPM scale animation
Hey Folkz,
1.
Take one clip and animate the scaling via BPM. Now it is not possible to retrigger the the BPM animation via click at the clipthumb. Only a click on RESYNC works.
2.
Trigger one clip, switch from Timeline to SMPTE....the clip stuck (I think because no SMPTE input is available)...then switch back to Timeline.
The clip is still freezed although play forward is marked.
Greetz
Re: Retrigger via Thumb not possible when BPM scale animatio
1. This would fall under expected behaviour, and is also how it worked on R3.
2. This is a side effect of the SMPTE mode. A clip in SMPTE mode is put in pause until the desired SMPTE timecode is reached. If you switch to timeline, it will remember the pause. Retriggering the clip will make it play again.
1. AH ok :) :roll:
2. okay...the clip is in pause, but the button still shows "play" :)
