finding logfile / memory leak ( ? ) / cant start avenue
VJair
Post by VJair »
where do i find the logfile to send in?
i had a big crash last night whilst in a club - it was a complete show stopper, i literaly had to show the promoter i couldnt get avenue to boot with any composition at all. ive thoroughly tested it at home for many hours and not suffered any big crashes, so i thought it was safe to use live - and because of this, id made the comp in avenue 4, not avenue 3, so i couldnt even load it in version 3.
i noticed before avenue bombed, it said "low memory" in red on the bottom right of the avenue screen and after it bombed i checked the task manager and watched the amount of available ram ticking down quite rapidly even though no other aps were running ( other than standard windows stuff )
i now cant get avenue 4 to boot at all with any of the comps ive used / made before with avenue 4.
this is on a well tried and tested laptop that hasnt bombed for me with anything else.
any thoughts / ideas / help ?
win 7 64bit / 4gb ram / core i5 2.4ghz / 2.4ghz / ati 5650
Re: finding logfile / memory leak ( ? ) / cant start avenue
Oh dear...thats not nice to hear! I hope your client still loves you?!
You can see and send the logfile here: Resolume / Preferences / Feedback / seelog
I have some additional questions about your "crash/f***", because I had a show last weekend...and it worked great:
- did you used midi / osc / smpte / artnet ?
- did you used flash?
- everything dxv?
- any third party software for sequencing or something similar?
- virtual midi cables?
- external or internal soundcard?
greets
VJair
Post by VJair »
You can see and send the logfile here: Resolume / Preferences / Feedback / seelog - i can find a preferences folder, but not a feedback folder and windows cant find a file called seelog
- did you used midi / osc / smpte / artnet ? - a midi controller
- did you used flash? - no
- everything dxv? - yes
- any third party software for sequencing or something similar? - no
- virtual midi cables? - no
- external or internal soundcard? - internal, but no audio used
:mrgreen: Don't search in the windows explorer :mrgreen: ....open R4 click preferences in R4 then...Feedback...and there you will find seelog.... *smile*...sorry that was a bit funny....but I'm drunk too right now...so nevermind! :P
VJair
Post by VJair »
see thread title - cant start avenue ;)
:oops: cant start avenue...sound like that you can't start avenue :roll:
In that case...did you tried to move all composition files out of the composition folder...to force R4 to start with a blank composition?
greetz
VJair
Post by VJair »
so am i likely to loose any logfile that i have hiden away on my machine if i try moving the compositions to get avenue to start?
im keen to try and help track down this problem as its a copmplete show stopper.
Good point - That's a question for goto&co.... I have no f****** idea 8-)
If you get a feedback from support...may you share it here?
greetz&good luck
VJair
Post by VJair »
more than happy to share info... just need to know what to do next first...
sometimes a direct mail to mail@resolume.com helps a bit faster.
Your problem sounds very urgent.
