Projection Mapping - How to get into it?
What is the equipment needed or the basics needed to start and try out with some projection mapping projects? I want to learn it and do for my company as well as side projects but not sure where to begin
						Re: Projection Mapping - How to get into it?
Its a really big question and there is not a straight forward answer. Each project you undertake will vary so the requirements change.
to start with you could literally just use 1 computer and 1 projector. This will be the best place to start. There are a lot of tutorials out there now which will be able to offer a little more insight into different aspects of it.
Hope this has helped and also check out this if you havent. - but this is just 1 example.
http://www.resolume.com/forum/viewtopic.php?f=11&t=6151
