Many Multiple Still Image Clips
bleeckerj
Post by bleeckerj »
Hello,
I'm a Resolume Avenue newbie, first off and I'm mostly a photography guy coming to the world of time-based media.
First experiment has gone a bit rough.
I have several hundred sequenced still images — time lapse. I would like to play through them using something like Auto Pilot but with the new transition effects in between. I can drag them all into a layer and Avenue will happily take them. I can create a cross fade that achieves the desired transition effect I would like.
Brilliant. Easy-peasy.
But — the default duration that each still stays on the screen is way too long for the aesthetic I am going for — 5000 milliseconds. I know where and how to change each one, but I don't want to do that for 538 images.
Select-All doesn't allow me to change all at once. It selects all the clips in the layer but there seems to be no way to say — change the duration for all selected clips to 750ms.
Also, I can find no place to change what the default is when a clip is dragged onto the layer — that'd be a work-around.
Do any more experienced folks have an idea how to do this?
Julian Bleecker
