no effects in Arena 4 download
lella
Post by lella »
Has this happened to anyone else? The effects tab is empty in the download I did today. No blend modes either.
Should I just try downloading it again?
HerrNieDa
Re: no effects in Arena 4 download
Post by HerrNieDa »
maybe the vfx folder is not linked correct...
look at the Properties and change/link the vfx folder(s) you need!
lella
Post by lella »
That solved it.
Thanks.
Sofiafio
Post by Sofiafio »
hi,
I've the same problem, today when i opened the effects were lost and how can i solve it? I couldn't find property, when i look at the application there are effects, but when i open program no
